Is KZ SPC upgrade cable worth it?
drkknghtavngr
The silver upgrade cable?
No. Get it if your headphone cable breaks.
idk
50 minutes ago, drkknghtavngr said:
Will sound quality actually improve?
Normally, I'd say 'No!', but I guess it really has to do with the IEM. I'd always believed that cable does absolutely diddly to affect SQ, that was until I'd tried an ALO Audio SXC 24 with my Fitear Parterre . Compared to the stock Fitear cable that came with the Parterre, I was surprised that I could hear a difference, but do bear in mind that was with a pair of higher end IEM's that apparently respond well to higher grade cables. But in the case of the upgrade KZ SPC cable, I'd say no....don't bother.
Main Rig: AMD AM4 R9 5900X (12C/24T) + Tt Water 3.0 ARGB 360 AIO | Gigabyte X570 Aorus Xtreme | 2x 16GB Corsair Vengeance DDR4 3600C16 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Topre Type Heaven + Seenda Ergonomic W/L Vertical Mouse + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 3900X + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Keychron K2 + Logitech G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
No, unless you stock cable is literal garbage, there’s no sound quality improvement with expensive cables, and silver cables are total snake oil.
yes my stock wire broke, what about bluetooth cable?? does it have issues??? hows SQ???
What headphones?
  • 10 months later...
Unfortunately as you can read in this head-fi thread https://www.head-fi.org/threads/knowledge-zenith-kz-impressions-thread.698148/page-842 plus my personal experience. Yes the Silver Plated Cable is not just an upgrade, basically removing anthing 'STOCK' form a KZ headphone apart from the actual earphone FIXES it. The first thing I did was change ear tips. it cleared up the highs mids and bass problem which sounded like it came out of a friggin drain pipe. Now with the upgrade cable (against all human understanding) the sound is like it's supposed to. clear, seperated and no frequency spots are missing and bass is even. it's such a big difference, that honestly when I got the KZ ES4s I used them with the standard ear tips and cable and I wanted to throw them in the trash can then and there (nearly did). Then I changed tips (which makes the biggest difference) and now with the Silver wire upgrade they sound as good as advertised if not better. If you do get the upgrade I'm sure you won't regret it. change the tips first tho.
Interesting...Unfortunately that kinda annoys me that the KZ IEM is $15 and then you have to spend another $15 for better tips and a cable. And then you spend over $30 before you know it. And some $30 IEMs sound so much better!
The Kz ES4 kinda impressed me when I first got them. Only because they didn’t sound like nails on a chalkboard knowing that they’re branded “KZ”. But over time I realized that the bass was muddy, the mids sounded weird (in a paper cup kinda way) and the highs were uneven. Now they’re sitting in a drawer. I prefer the ZSA out of the box personally. They just sound cleaner but the highs are unpleasantly sharper.
But the KEF M100 on eBay for $30. I swear that nothing sounds better for the $. These IEMs are basically flawless. They have a FLAT frequency response without any noticeable flaws. If these were from a Chinese brand they would get a lot more hype. So why buy cheap IEMs only to upgrade them with better cables and tips when you can buy something flawless for around the same money?
