So,
today i recovered a old server from my dads work. Its an old windows server running on windows xp. But it has 3 ethernet ports and no mather wich one i connect to i cant acces the internet. Can you help me with this. Also can i install windows 10 home on this machine? I would use it for gaming.
https://linustechtips.com/topic/889435-server-motherboard-ethernet-problem/
2 minutes ago, OlivierThePro said:
So,
What model is the server?  You will probably need to download the drivers on another machine and install them manually from a USB.
That could be any number of things and since 3 is an odd number one of those is probably a console/maintenance port.
Do the interfaces show up under network connections just as disabled?
What is it? Model? If it’s running XP it isn’t too likely to be good for much these days as far as a gaming workload goes.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
For a xp server machine, it may not have PCI-Express, you cannot install a decent GPU to play your games.
I think the machines is a xeon from pre core 2 era. You will need to have core 2 quad to play modern games smoothly.
Reset the network configurations to use the internet. As the LAN port may have some proxies.
