I was thinking about making a build with a custom water loop in it and I was wondering if it would be hard to add a second graphics card into the loop later down the line if I wanted to upgrade.
Here is the build https://uk.pcpartpicker.com/list/nZswwV
It will be the first time I will be making a custom loop.
https://linustechtips.com/topic/888846-changing-custom-water-loop/
wont be too hard, you would have to redo the area around the GPUs but thats about it probably
Builds:
22 minutes ago, Damascus said:
Yeah, adding an extra gpu is very easy.
It's not very difficult you would need some extra fittings and a second block. If your doing hardline tubing though you will need to make some new sections of tube.
Might not even need extra fittings if they used a terminal
Want to custom loop?  Ask me more if you are curious
Adding a second GPU down the line is easy. But have you thought about getting an EK aluminum kit? The P280 doesn't come with a GPU block, so you'd have to add about 90 quid for that, so you're at almost 400 bucks for a loop with a single 280 rad. With the aluminum A240G kit you get everything you need for the price of the P280 and you can throw in an additional 360 rad with fans and fittings for less than the copper GPU block would cost.
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 2x16GB Mushkin Redline @ 3200MHz 16-18-18-36 GPU: GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad w/ Scythe Kaze Flex, dual 45x540mm external rads passive, Nickel Plexi EKWB blocks, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 1TB Samsung 980 M2 SSD, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS & Proxmox:
CPU:  Epyc 7302 MoBo: Supermicro H11SSL-i RAM:  8x32GB @ 2666MHz Samsung Registered ECC  Cooling: Enermax Liqtech TR4 II 360 w/ Corsair ML120 Case: InterTech 4F28 PSU: Seasonic Focus PX-650 Storage: 8x6TB HGST + 2x1TB WD Blue SN570 + 2x16GB Intel Optane SSDs Network: Mellanox ConnectX-3 10G
ML-Compute Server:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 4x8GB HyperX Fury @ 2133MHz8 GPU: Gainward GTX 1080TI Golden Sample Cooling: Single 30 Case: RackMax 2U 8-Bay Storage Case Storage: 512GB Patriot P300 + 4x2TB Seagate Ironwolf NAS Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus Nord
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: KBDFans 65Rev2 Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
