How to fix a VERY sensitive key (laptop)
Solved by TheKalmTraveler,
Open the Laptop and search if something got stuck in the key.
You could also use an Air Spray to Blow the Key free but if one key got stuck I would rather make a full clean up and reassemble.
Featured Topics
nulcow ·
Posted in Laptops and Pre-Built Systems1 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
1
HyperPalBuddy ·
Posted in Audio0 -
1
wyndwalker ·
Posted in Power Supplies2 -
okkee ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
