Posted January 21, 2018 Hi, I've a computer with a i7 7700k processor with a kraken x52 liquid aio cooler. I have getting temps around 30 degrees Celsius idle and 80-90 Celsius under load.. Is this to hot? Here's some more information that may help: I thought the temps were to hot... so i looked at my CPU I am getting 4.79 ghz and haven't overclocked could this be a factor? Also my aio liquid temperature is low but the cpu is hot... Lastly when i first boot up the cpu is at like no use but when i open an application (like steam) it shoots up to 4.79ghz.. All answers/ discussion would be appreciated... Thanks-Beefy Link to comment https://linustechtips.com/topic/888262-cpu-to-hot/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2018 80C is very hot. You should try remounting your cooler, and make sure you removed the sticker on the bottom of the block (if there was one). Either your frequency is being read wrong, or you have your CPU overclocked. It shouldn't go above 4.5GHz at stock speed. See if your motherboard has an auto-overclock feature. If it's enabled, disable it. Make sure to quote or tag me (@JoostinOnline) or I won't see your response! PSU Tier List | The Real Reason Delidding Improves Temperatures | "2K" does not mean 2560×1440 Link to comment https://linustechtips.com/topic/888262-cpu-to-hot/#findComment-10960461 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2018 Also check the voltage, i.e. vcore. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/888262-cpu-to-hot/#findComment-10960474 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2018 Also depending on his room temperature. That normal temperature for computer in Australia ... I mean you should try to keep below 80 degrees but 90 degrees is quite high. It normal for your cpu to boost cpu frequency when you start application. Also what software are you using to monitor the temps and frequency? Windows task manger is good program to monitor cpu frequency. Magical Pineapples
