So I'm running an overclock of 4.0GHz at 1.375  and while I was running the stress test and benchmarks I noticed that my mouse would occasionally lag, is this a problem with the overclock or my mouse?
Also are these temps good for a Gammaxx GT RGB (air cooler): Idle: around 30-35°  and during benchmarks and stress test around 50-60° (never reached 70°  in any of the tests)
Is this a safe overclock to run in everyday use?
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/
1.375 is a pretty hot voltage and i would place it at the very top edge of safe 24/7 OC. If your LLC doesn't push VRM voltage above 1.375 for prolonged periods of load and is adequately cooled, it's safe... but i've not seen a VRM with LLC that stays at what you set it to under load. It usually goes much much higher. You need to find out what voltage your VRMs are sending to the CPU.
system lag is expected with a cpu under 100% load.
70*C is a good load temp.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10958679
that kinda oc largely depends on ur motherboard, i'd be much worried about the vrm than the cpu, also i doubt it is actually 60C as ryzen temps can be a bit janky, it should be closer to 70-80 (which is still fine as long as the vrm temps are in check)
whats ur motherboard.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10958691
Would a 1.35 voltage be fine?
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10959092
Yes, AMD recommends a 1.4v maximum.
*For system longevity
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10959249
1.35 would be fine, but i would be surprised is you can sustain a 4.0GHz OC with that voltage.
System specs:
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10959642
1.4125 is maximum for longevity according to amd. also, xfr boosts well over 1.4 in many amd cpus
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10960050
XFR is also dual core only which doesn't load the CPU nearly as much as an all core OC, which means a crap-ton of current.
System specs:
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10960194
its mostly voltage that burns out the cpu, current doesnt do much
https://linustechtips.com/topic/888104-temps-ryzen-5-1600x/#findComment-10960200
