Mining with RX 580 or 1060?
Solved by mariushm,
Depends on coin
Ethereum and coins using same algorithm are mined better on RX 570 or RX 580 but gtx 1060+ isn't far off (note you need 4GB memory to mine ETH, 3 GB cards may still work for a few months)
zCash and other coins using the Equihash algorithm do better on nVidia cards
Some Cryptonight based coins (monero, dash) may also do slightly better on nVidia
see http://whattomine.com click on the card model and enter quantity then hit calculate and then pick a coin to mine which you can easily trade (not electroneum which can only be exchanged in one place for example)
