Hi!
I want to upgrade my mouse and keyboard.
I currently use a Deathadder, but the tracking is weird and the clicks are too subtle.
I am looking at 2 mice at the moment. I use a mix of palm and fingertip, where my palm touches the mouse but my fingers have a small space between it and the mouse.
- Zowie EC1-B
- SteelSeries Rival 600
Which is better?
I currently don't have a keyboard, (on my laptop rn) and I am deciding between these 3:
- Ducky Shine 6
- Corsair K70 Lux RGB
What should I choose?
(Blue switches btw)
https://linustechtips.com/topic/887542-upgrade-help/
- Zowie EC1-B
I'm not sure you're going to end up using all the features of the 600, so take a minute to ensure that its worth the extra $20 to step up from the Rival 310.
- Fnatic Gear Rush Pro Gaming
- Ducky Shine 6
- Corsair K70 RGB Platinum
Depends on how much RGB control you want, and if you want dedicated media keys. As a K70 owner, I can easily recommend the K70. There is no K70 Platinum, by the way. The next step up would be the K95, which doesn't offer Cherry MX Blues.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10953530
Rival 600 is overpriced just because it has overkill sensor and gimmicky lift off distance.
I'd just get the Zowie u wont regret it they has a really safe shape.
and it has one of the best optical sensor PMW3360.
as for the keyboard i'd get the K70 Brown
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10954232
4 hours ago, Omnifizix said:
What does the K70 have over the Ducky and vice versa?
@Homeless Pineapple
1
The K70 has a more flexible suite of dedicated media controls (Play/Pause, Stop, Next Track, Previous Track, Mute, Physical Volume Wheel), individual key RGB customizability with community-made profiles, has a USB passthrough and comes with a wrist rest.
The Ducky has a detachable cable, dedicated volume keys, removable rubber feet, and has side RGB lighting.
Desktop
Homelab
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10959791
Thanks a lot! Does K70 have a better build quality and are the lights bright? I think I might go for the K70 now :D Sorry for all the questions!
@Homeless Pineapple
K70 LUX RGB BTW
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10959879
On 20/1/2018 at 9:49 AM, Omnifizix said:
I think I will go to a store and try out the Ducky and Corsair.
Does the zowie have any problems?
No they make the best simple mice ever without tons of gimmick like other gaming manufacturer always does.
1 hour ago, Omnifizix said:
Difference between K70 LUX RGB and K70 RGB?
LUX RGB has new controller for a more fluid lighting, USB Pass through and STRAFE keycaps comparing it to the older K70 RGB.
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10960536
@Homeless Pineapple
K70 LUX RGB BTW
The K70 LUX is constructed of brushed aluminum. It feels very premium and the keycaps seem to be holding up very well. The lights are bright enough to be seen from any viewing angle. The Ducky Shine 6 is plastic.
The CUE software has also gotten a lot better. If you're willing to spend some time in Advanced mode, you'll be able to make custom profiles in a breeze.
Desktop
Homelab
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10960644
If you are still looking for a mouse, I can VERY STRONGLY recommend the Logitech G900 Chaos Spectrum
I use the same style grip as you, and this mouse is VERY comfortable and light, and the "less subtle" clicking you asked for is definitely a feature as well, since it uses a different architecture than normal for main mouse buttons
both wired and wireless modes have a 1ms latency
it is UNBELIEVABLY good, the battery life is insane, 32 hours on full charge, with lighting off mind you, doesn't really make a huge difference anyways
the software for configuring it is also very easy to use, you can see it at the bottom of my post. I took several so you can extensively see the software you would be using before buying the mouse. the software is free by the way and its name is Logitech Gaming Software
Hope my post really helps you out in your decision, this might just the the last gaming mouse I ever buy!
here are some very in depth videos covering this mouse
from LTT
this will be from the viewpoint of someone who has YEARS of experience with FPS games, and the G900 will be compared to several other mice
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10960790
textured space bar - yes, looks like this
aux output port - no, not mention in the features, and no picture of the backside of the keyboard near where the main cable is, where I would expect it to be found
ALSO you should note that I did not see a Cherry MX blue switch version of the non platinum K95
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10960823
@TheMusicalPALADIN
https://pcpartpicker.com/product/YwrcCJ/corsair-keyboard-ch9000061na
Blue MX K95.
Also I can't really see the texture on the K95, is there a clearer picture?\
Edit; I just read that it was discontinued :(
Looks like I'll be getting the Ducky.
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10960829
if this is the one you are talking about....
in my opinion that is a pretty fishy buy
instead of having a solid and durable attached cable, its a micro usb cable going between the computer and keyboard. honestly havent seen that before in a GAMING oriented keyboard, where you would think durability should be a focus point. Have you seen any reviews on it?
https://linustechtips.com/topic/887542-upgrade-help/#findComment-10960840
