So i have  a NH D15 for my r5 1600x and i just did a Pcmark test for it a few days ago. It said that my CPU hit 73 degrees celcius while is was rendering and visualisation. BUT all other test under full load ( i assume) didn't really hit over  65, 63, 69 degrees and my GPU a Galax GTX 1080 actually got COOLER results on average then my cooler did. So i'm wondering should i apply more thermal paste? As i only applied about a grain of under cooked rice size of thermal paste. But keep in mind i live in AUS and we have about 27 to thirty degree temps ambient because its summer. and its a six core processor. suggestions or comments?
https://linustechtips.com/topic/887520-need-advice/
You have to remember that all temperature readings are made with a set ambient temperature. So, if your room is hotter than the room that other people have tested theirs in, then yes, your results will be higher. I think you're fine.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/887520-need-advice/#findComment-10953309
I'd say replacing the standard NF-A15s (~83CFM) to some more powerful fans like the NF-A15-3000 (160CFM).  You'll be trading sound for lower temps, but that should only be noticeable on stress testing. You also may have to jerry-rig the 140mm fans on - they're not on 120mm mountings.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/887520-need-advice/#findComment-10953318
You could also switch to a 240mm or 280mm radiator - You'll get even better performance. I'd recommend a 280mm - better airflow and more area. The 1600x is a higher wattage CPU than most others.
I feel your pain regarding ambient room temps - back in 2011, we had something like 70 days over 78C.
https://linustechtips.com/topic/887520-need-advice/#findComment-10953342
