PSU: Corsair RM850x
Since my GPU required two 6-pin power connectors I used two sets of PCIe power cables connected to the two 8-pin slots in the PSU. After watching the LTT video on the 2200W PSU, it got me questioning my setup.
-Would it have been fine if I only used a single PCIe power cable since the cable has a couple 6/8-pin connectors?
-If I ever go SLI/CrossFire and that both GPU’s require dual 6 or 8 pin connections, would the cabling be a single power cable for each GPU, or two power cables connected to both GPU’s?
Any helpful answer is appreciated.
https://linustechtips.com/topic/887344-power-connectors-for-single-multi-gpu-set-up/
20 minutes ago, Dissitesuxba11s said:
PSU: Corsair RM850x
two 6pin connectors = one 8pin one.
So everything is fine for your setup.
If you go by spec of the connectors and pins, even 8+6pin is still (barely) OK. 2x 8pin is not however.
So if your GPU had two 8pin connectors, you should use one cable per connector on the Graphics card.
For  a 8+6pin setup with 2 cards I'd use three cables tbh. 2 8pin and one for the two 6pin.
"Hell is full of good meanings, but Heaven is full of good works"
8 minutes ago, Dissitesuxba11s said:
So for example I have two 1080TI's like the one below, would I require four 8-pin cables?
  Hide contents
Yup. You can't run the card without that configuration. Might give an error during POST if you used anything different, like a single 8P or a 8P + 6P setup. MUST be 8P + 8P.
Therefore, would this theoretical set up require a PSU with four or more PCIe connectors?
Yup. For that card one cable per connector would be a better idea.
Some PSUs might have a 6P breakout cable but ignore that. That's good if the GPU had a 8P + 6P connector and you wanted to do the run with one cable or maybe it's a cost saving measure.
Thanks for the clarification. Now I know my PSU is adequate if the need arises.
  Reveal hidden contents
Yes, for those.
Seasonic has a great picture under  'Installation remark for high power consumption graphics card':
https://seasonic.com/faq/
That picture says it all.
10 minutes ago, Stefan Payne said:
Yes, for those.
In my case where my 980 has two 6-pin connectors, would I have been fine even if I only used one PCIe power cable connected to both 6-pins? Asking this since the picture shows not to do that set up.
Reference pic:
Yes, since its 225W TDP or less.
And, as I stated earlier, 2x 6pin equals one 8pin.
Both equal 150W specified.
Thank you for all the input, now I'm even more confident on my PSU.
