I have an asus strix X370-F gaming motherboard and I have installed in it a sound card, 1080ti, nvme ssd in the bottom x16 slot. I can put it in the M.2 if need be. The problem is that when I install my 1050ti the computer doesn't display and when I push the power button while it is on, it shuts down immediately meaning it didn't boot to windows. Why can't I have both cards installed? They both work individually.
https://linustechtips.com/topic/885566-multi-gpu-no-work/
PSU?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/885566-multi-gpu-no-work/#findComment-10934367
2 minutes ago, Leonitus454 said:
It's a 650 watt from Rosewill that may be the cause, are the they symptoms of not having enough power?
Yeah, that's not enough power, probably. What model is it BTW?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/885566-multi-gpu-no-work/#findComment-10934389
Rosewill ARC Series 650W Modular Gaming Power Supply, 80 PLUS Bronze Certified, Single +12V Rail, Intel 4th Gen CPU Ready, SLI & CrossFire Ready - ARC-M650
https://linustechtips.com/topic/885566-multi-gpu-no-work/#findComment-10934394
650w is plenty for that
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/885566-multi-gpu-no-work/#findComment-10934589
It's powerful enough, but either way IMO you should change it.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/885566-multi-gpu-no-work/#findComment-10934901
