Wrong section... And no, no need to update your bios, unless something isn't working.
https://linustechtips.com/topic/884968-help-needed/#findComment-10929446
1 minute ago, Nexblitzer said:
I have version 0802 BIOS on my motherboard form Asus. and i have just built my system. so should i update my BIOS? all i have done so far is play some games and they run pretty well and just web browse sooo?
Which mobo ? BIOS updates are always nice cause they fix a lot problems. If you have Intel then you must update to fix Intel ME bug and if you have Ryzen then update for memory compatibility.
PC Specs : i7 7700k, 24 GB @ 2666 MHz, ASUS Strix GTX 970, ASUS Z170-K, 960 EVO 250 GB, 850 EVO 250 GB, 2x 2 TB WD Purple RAID 0, Green 1 TB
https://linustechtips.com/topic/884968-help-needed/#findComment-10929447
