Best way to mount PSU ?
Solved by MkaiL,
1 minute ago, Intel HD Graphics said:oh i thought is sucks air from the case, lul
It does. The fan blows directly onto the psu components and air gets pushed out the back. If your case has a filtered psu intake on the bottom and you don't plan on putting it on carpet or obstruct it in another way, point the psu fan down. This way your psu won't have any effect on temps and airflow inside the case.
