I recently purchased a EVGA 1080 ti FTW3 (coming from two MSI 980 ti's GE). And I find that what I used to do to switch between DSR settings in games is not working anymore. I used to be able to just switch to 4k resolution In-game. Now I cannot seem to enable it at all. I'm currently being limited to 1080p in all games while in-game, and Geforce experience allows me to change my applied settings to 2k, and 4k, but then I get in-game and it's right back to 1080p. Anyone else have these problems? I seem to be able to change my desktop to 4k just fine.... I am confused, and it's probably something just really dumb I am overlooking.... Any thoughts? Thank you in advance for any assistance.
https://linustechtips.com/topic/884449-1080-ti-dsr-problems/
6 minutes ago, WereCat said:
If you have 144Hz it wont work
it works just fine
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/884449-1080-ti-dsr-problems/#findComment-10924041
i'd just nuke your drivers with ddu and reinstall the latest ones
https://linustechtips.com/topic/884449-1080-ti-dsr-problems/#findComment-10924050
Have you gone into the NV control panel and re-enable the scale factors (you can set like 1.2, 1.5, 2.0, 4.0 scaling factors in the control panel)
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/884449-1080-ti-dsr-problems/#findComment-10924085
 2X, and 4X were enabled. I did not enable all of the factors tho.
https://linustechtips.com/topic/884449-1080-ti-dsr-problems/#findComment-10924095
28 minutes ago, WereCat said:
I think it depends on the display connection.
For example HDMI 2.0 is rated for 4k 60Hz so 4k DSR on 144Hz 1080p will also function only at 60Hz.
Yeah, the monitor I have only has 144hz through the DVI-D port.  Setting it to 120hz works fine for DSR apparently tho, with my setup at least. Don't know why I did not have to F with it at all before but ehh w/e. 120 should be fine for 4k.
https://linustechtips.com/topic/884449-1080-ti-dsr-problems/#findComment-10924535
