So im curious.
 say u have a aio cooler and your liquid temps around 25-30c under load
and staying stable at that temp but cpu temp is around 85ish.
For arguments sake, say u have a single 140 rad aio.
Would buying a bigger aio say a 3x140 see a difference in cpu temp.
Or is that baby aio basically doing it's job?
At what liquid temp would u say it wouldn't change the temp?
https://linustechtips.com/topic/884445-liquid-temp-question/
If there's that much of a temperature difference between the liquid and the CPU, the water block isn't making good enough contact. Assuming everything is good, "stable" temperature is where the liquid and CPU are roughly the same.
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10923967
i'm 27c on the water temp at like 40c on the CPU, haven't checked it during stress testing, but the water is always gonna be colder then the CPU itself, you don't have 100% efficiency in any system, the more water and surface area you have the better heat transfer you will get, but neither will or should ever be equal, Water stays much colder, infact any temp over like 60c on water is actually bad for the cooler, as for whether your cooler is to small that depends on your CPU and how much an overclock you have going
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10924074
58 minutes ago, LangleyNerd said:
So im curious.
There are allot of variables to take into account. The more cooling space you have the better the temperatures will be.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10924186
That means you don't have adequate heat transfer from the CPU to the block.
Most of the time the issue is a bad mount causing poor transfer from the IHS to the block, change the thermal paste and remount it as flush and evenly as possible. The difference you are seeing is almost certainly from this.
The other possible issue is bad transfer from the CPU to the IHS (Intel only) which has been an issue for heavy OCers and can be fixed by delidding, but this would not explain such a huge difference and is probably not your issue.
For reference my i7-6800k with an H110i GTX after 15+ min under load sits at 62C while the water temp sits at about 43C. Even without delidding you should be getting the CPU and water temp within 25C or so of each other after extended load. If you don't then you need to remount it better.
If you AIO liquid is sitting near room temp then getting a bigger one wouldn't change a thing since it's already keeping the liquid as cool as possible and a bigger rad wouldn't change that. A bigger rad would only help if the liquid temp is high and the rad can't dissipate the heat well enough to keep up with heat generated.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10924228
along with what @pyrojoe34 said, another explanation is that you haven't run the stress test for long enough to equilibrate your AIO coolant temperature.
Water takes a long time to heat (and cool) and so you need to stress your system for a good half hour or so to let the coolant reach a final temperature
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10924721
thanks for all the replies.
Im building another system for the wife, same build as i already have
i7 8700K
msi z370 msi plus
16GB DDR4
i have a spare NZXT i shoved on it against my own wishes and i just ran prime95
for 3 hours maxing temps were at about 87C for over two hours and liquid temp never went above 27C
ohh PS 5ghz overclock
Vary stable except for this odd discrepancy in temp from liquid to CPU.
i ran out of thermal paste will grab some tomorrow and try again..
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10925109
i7 8700K
msi z370 msi plus
16GB DDR4
Yea something is wrong, is the pump running? Usually the liquid temp sensor gets hot when a pump fails though... Maybe a bad sensor? Did you already try remounting it with fresh paste?
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10925217
`So why do you need the liquid temps to go up?
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10928078
how did you measure liquid temp?
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10932615
If the room your in is cold then you can run cooler,Are you getting your temps out of a program or motherboard off the cpu ?The basic of cooling a cpu water or air is can the cooler keep up with the tdp heat from the cpu.On a stock clock speed most aios will run cool if the room its in isn't hot.Now once you overclock you dump a lot of heat,Or the room its in is 90 degrees f then things are gonna get hot fast.
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10933117
Alright so I kinda figured it all out.
I removed the cooler and noticed that there was play in the backplate when u screw down the cooler.
Pretty sure i read about a few instances of this. So I grabbed a few rubber grommets from an old hard drive bay tray that had rubber spacers.
I linused them together to fully tighten the cooler down.
That being said.
A 3 hours of prime95 torture test at 5.0hgz
cpu temp 82 degrees
Liquid temp 37
I have come to the conclusion it's a prime candidate for delid.
I have checked the cooler and it's working as it should.
Thermal compound spread on cpu and cooler are as they should.
Only thing left is to assume it's the shitty thermal paste on the die itself.
https://linustechtips.com/topic/884445-liquid-temp-question/#findComment-10944781
