Well hello there im thinking for the past month or two to build a pc why? well im in my 2nd year uni so i figured why not play a little
i do currently have a pc here are the specs
Case- NZXT H440
Prcessor- i7-5930k
Ram- Hyperx 64gb
Cooling-  H60
Storage- 480GB SSD, 2tb Hdd, 1TB Hdd
Motherboard- Msi X99A gaming 7
Video Card- GTX 1080 strix
Power supply- Corsair HX 850
I used to have a 780ti installed but upgraded to 1080 for vr gaming
now im thinking should i build a pc from scratch or should i simply upgrade ?
btw i do have a couple hdds lying around probably 3-4tb in total so i was thinking of doing a raid(unfortunately dont know how) for the new build, i do know my pc is a little bit crazy on ram but i used to have alot of applications that use ram + i multitask.
ahh yes i would like my new pc to be fully rgb.
Now to the budget probably 1300$ and i do live in the Middle east(Kuwait) (our pc market do have 10% inflation)
So i would like your suggestions/opinions ?
Thanks
 Meoww
https://linustechtips.com/topic/884142-building-a-pc-first-time/
I'd invest in upgrades instread of building a completely new one, get a m.2/pcie NVME ssd, otherwise this is such a high-end machined that you simply have nothing to justify the price of the upgrade.
Mabey get a replacemnet for the h60, h80i v2 mabey? i am very satisfied with it.
What upgrades do you think you need? I can't really see anything that would give you any real tangible benefit.
Maybe a 4k monitor and a 1080Ti? An NVME drive for Windows?
The cooler's kind of shit and you live in a hot country...though I'm assuming you have air conditioning. Throw one of Corsairs new H150i's in there.
Welcome to the forum :)
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yeah totally just upgrade. M.2 Seems like a good idea, you should get one and install OS on it. other than that you can't have enough RGB, I've been using the NZXT hue for 6 months+ and I can recommend it. I can also recommend a 1080 ti and a 4K monitor, though you should get one with a decent IPS or OLED panel. an another option is 1440p 60 or 1440p 144hz.
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
True im thinking of getting a m.2 but i do have like 4 hdds lying around and my ssd is pretty much good and tbh i dont care if it takes a little time to load
well i thought of getting a new 1080 to sli but the case is little bit tight that i need to remove some hdd drive bay to fit so you could say a new case probably a 570x
2 minutes ago, johnny5c said:
You're not going to build anything better than what you have for $1300, if really want to play a little build a custom water cooling loop.
will take time + needs to much work put on it to simply work the way i want it
Mmm....nah. SLI isn't really that great, not everything supports it. I'd just get the 1080Ti.
I'm looking at a 570x with the shrink wrap still on the tempered glass panels right now ;)
Gorgeous case. Definitely something you appreciate more when seeing it in person.
Your PC is very powerful. You can get a M.2 PCIe SSD and RGB fans. But I would suggest you to buy a good monitor.
CPU: R5 1600 | Motherboard: Gigabyte AX370 Gaming 5 | RAM: Gskill RipjawsV 3200 MHz 2x8 GB Black | Case: Phanteks Eclipse P400 | PSU: EVGA 650 G3 | SSD: Samsung 850 Evo 500 GB | Graphics Card: MSI Armor RX 570 4G OC | Wi-Fi Adapter: Asus USB-N14 | Headset: Arctis 5 | Keyboard: Masterkeys Pro L Cherry MX Red | Mouse: Logitech G402 | Mousepad: Logitech G240 | Monitor: Viewsonic XG2700-4K
Oh and i forgot im thinking of getting a X62 kraken but the case is a little bit limiting me
Well the 1080ti is powerful but the problem is what should i do with my current 1080 and im thinking of skipping the 1080ti in the upgrade plan because i would like to go straight to the
Titan
well i currently have a 4k 60hz monitor (Asus ROG PG27A)
  Reveal hidden contents
Titan
The xx80Ti is almost always as powerful if not more powerful than the Titan of the same generation.
You could sell the 1080.
