What's the difference between socket 1151 and 2066?
Are there any differences in performance or anything significant?
Because I noticed 2066 mobos cost a lot but 1151 mobos cost not that much.
The only difference for the sockets themselves is the pin count: socket 1151 has 1151 pins, and socket 2066 has 2066 pins. There is no difference between their performances, they're only aimed at different tiers of processors to provide the necessary support for them to function.
The reason why 2066 socket motherboards (X299) are more expensive is because they're within the prosumer platform, aimed to go with much more expensive high end CPUs, as well as including more unusual features.
...aaand the fact that they're simply overpriced.
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
Physical difference more pins, so you need a higher end cpu too. You most likely dont need that cpus so stick with 1151 and their cpus
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
The 2066 is a much bigger socket and it's made for higher-end CPUs. In turn it has higher-end features and generally motherboards in the LGA 2066 are more built with bigger VRMs and more (8) RAM slots.
As for performance differences, you can't compare both because they can't house the same CPU.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Extra pins 915 pins on socket LGA 2066...
No, the LGA 2066 socket (AKA X299) is Intels' Extreme platform.
LGA 1151 is their Mainstream platform.
LGA 2066 Core i9-7980XE 18 cores, 36 threads, $2000 USD.
LGA 1151 Core i7-8700K, 6 cores, 12 threads, $260 USD.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 6800 XT Special Edition Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
pin count, feature dynamic, cpu support. Most normal users and gamers don't benefit much from going to the "enthusiast" platform. Mainly you can use higher core count cpus and, if supported by the cpu, ecc memory (doesn't matter for most things) which matters for streamers or workstations
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
I was gonna comment about how Intel had now released X399, then I remembered that's AMD's chipset name. Y U DO DIS AMD
Computer Specs:
Not the same, but very close - 7600K vs 7640X, and 8350K vs 7640X.
idk
I chose to omit those because I'd rather deny that the 7740 and 7640 exist :P
Computer Specs:
Let's take 7640X and 7600K as an example.
7640X is cheaper and better, why? Is it because of the mobo high cost?
The cost of the mobo offsets it, yes.
But the i3-8350k exists which is the new 8th gen equivalent of both of those chips.
idk
The i5-7640X is cheaper, but everyone, including reviewers, are still tearing Intel a new a$$hole about it.
Did you see Linus' "Ranting in the Rain" video?
And here is Gamer Nexus also saying like "WTF is this".
And you got Paul from Paul's Hardware saying "$250 CPU in $490 motherboard? Wat?"
Etc.
i5-7640X and i7-7740X should not exist.
It's a LGA 2066 chip cut down to i5-7600K and i7-7700K level, along with a BUNCH of stuff on it disabled.
Intel's *marketing* was the 7640X and 7740X is a "temporary place holder" CPU for people who WILL upgrade to something like the $2000 i9-7980XE.
The problem is, you need to use it on an expensive X299 motherboard, BUT, you are only limited to 16 PCI-E lanes, and only CERTAIN RAM slots work.
Also like 3/4 of the features on X299 are disabled if you use a i5-7640X or i7-7740X.
Get a i7-7700K...but with a $500 motherboard instead of a $150 one!! Heeey!!!
You either go with a i7-7700K or i7-8700K, or commit fully into X299.
  • Ekwb Custom loop
AMD Ryzen Rig
  • AMD R7-5800X
  • 2 months later...
Incorrect.  They just don't add pins for fun or to make them incompatible, they are a compromise between functionality and cost.  The LGA 1151 is cheaper because it is cheaper to make motherboards for -- and it is fine for your average gamer (where the LGA2066 would be overkill).  If you don't need it for what you do, then don't buy it - but just because it is not for you does not mean it does not serve a function.
What do these extra pins on the processor/motherboard give you?
Potentially double the PCIe lanes (24 vs 48).  On the gamer board (1151) you will get a maximum of 24 lanes, on the LGA 2066 it will support up to 48 lanes.  The more lanes the more concurrent throughput.  After maybe a GPU (16 lanes), and a M.2 SSD (4 lanes), chipset (4 lanes I believe for the rest of the onboard functionality I believe including a 1Gbit Ethernet port) - you have to basically implement some sort of "bandwidth management" (i.e. switch) which means throttling bandwidth to your CPU.  I said potentially double since you need a reasonable processor to take advantage of it (10+ core Skylake or Xeon W).
Up to triple the core count.  6 vs 18 (the next consumer socket -- not likely to be compatible with the current 1151 -- likely a max of 8 cores).
Double the memory bandwidth, i.e. quad channel memory vs dual channel (again more bandwidth) - which means to get the most of it you install memory in sets of 4.
Double the memory slots (8 vs 4).
Double the maximum memory allowed installed (128GB vs 64GB).
If you install a Xeon CPU you can also install ECC memory.  According to a UofT study, 32GB of memory will average about one-bit error per hour.  This does not mean bad memory, just an undetectable error in what you are computing.  For gaming, something like this does not mean much, but when what you are doing is life or death type stuff or you cannot afford the chance of an error - it is better for the computer to know that something was wrong with the data.
If your primary use of your computer is gaming - then lga1151 is your best bet since you are not likely to use any of the benefits of the higher pin cousin.  If you use your computer for other tasks - you have to evaluate whether the LGA2066 is a better fit.
So no, just adding pins is not the answer... pins actually hook up to stuff.
