Where to plug in my monitor?
Solved by Guest,
It matters alot. an graphicscard usually is alot better then integrated graphics, especially if you are using an Intel CPU. And therefor, you want to use the best graphical processor for your main display >>> plug it into your GPU. If you have got multiple monitors, it might be usefull to offload some of the work to your internal graphics.
Featured Topics
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices1 -
Abaris ·
Posted in Troubleshooting2 -
2
SpookyCitrus ·
1
Hey_AND1 ·
Posted in Peripherals2
