Harddisk Sentinel and CrystalDisk Info are both showing status and temperature as unknown for both of my drives(128GB SSD and 500GB HDD). CMD's WMIC S.M.A.R.T checker is showing "OK" (although I do not know where the rest of "OK"s came from) . Should I be worried? Are my hard drives dying?
https://linustechtips.com/topic/882494-unknown-smart-health/
Try to use the latest software and maybe change your HDD Controller to AHCI in BIOS.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
https://linustechtips.com/topic/882494-unknown-smart-health/#findComment-10905130
They most likely aren't dying, it's just that the program can't access the sensor data for some reason. Since the smart check shows "OK", they're probably fine.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/882494-unknown-smart-health/#findComment-10905135
software is latest. Just changed to AHCI and it fixed the health problem of the HDD. Temperature for the HDD is still not showing and nor is either temperature or health of the SSD.
https://linustechtips.com/topic/882494-unknown-smart-health/#findComment-10905153
