I'm having trouble with a build and it's that I want to use 12 fans but I'm not sure I will be able to use them all with PWM on the same software, let me explain. So I know 12 is a lot but please don't talk me out of it and the reasons I'm gonna use 12 is because:
1) Do as I say, not as I do (it is overkill but I want it)
2) I want to take advantage of the number and put not so high rpms on my rads (top, front 360, and bottom 240)
3) Aesthetics
The reason I'm having trouble is because I want to use the NZXT GRID+ V3 but that only takes 6 fans or 8 If I use two y splitters so I can't fit 12 fans but if I use the motherboard I can definetley I achieve it (asus maximus X hero motherboard). Why not do that? because I want to put everything on the same software and work it out on cam and it would be really annoying to not do that. My solution is simple but I don't know if it will work, I want to know if I can use two NZXT+ Grid V3 to be able to connect 12 fans total. Help in any way please :)
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
https://linustechtips.com/topic/882238-fan-count-help/
Why would you ever want the fans to run at different speeds?
https://linustechtips.com/topic/882238-fan-count-help/#findComment-10903160
