I have no idea how fittings work
Guest
I am beginning to try and make a custom water loop, and i have everything down, besides tubing and fittings. How do i make sure that the tubing and fittings are compatible with each other?
Depends if you're using hardline tubing or soft tubing and barb, push in or compression.
Compression is really the most common now. For that, you need to match the ID and OD of the tubing and fittings.
EDIT: Basically:
Barb: Match the ID of the tubing to the barb
Soft tube compression: Match both ID and OD of tubing and fitting
Hardline compression: Match the OD of the tube and fitting
Hardline push-in: Match the OD of the tube and fitting
For soft tubing you want to make sure for compression style ones the ID and OD both match, for bards just the ID has to match.
Hardline compression fittings similarly you want the ID and OD to match but also must note which brands you are using if the tubing and fittings are not the same manufacture as there is both inch and metric exact tubing.
On hardline compression, only the OD needs to match as there's no central barb like there is on soft compression fittings.
Also, OD = Outer Diameter and ID = Inner Diameter
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
What fittings and tubing are you wanting to use?
Edited by W-L
Just now, W-L said:
Yes that is correct, what fittings and tubing are you wanting to use?
You're asking the original poster right... Not me?
Retrowave
Set Up
  • Audio
uhh i will be using an EK Supremacy block and a GTX series card block. Im clueless so whatever you recommend would be great
The blocks you're using doesn't really matter as pretty much everything uses G1/4 threads. Pretty much all fittings and all blocks you come across will use G1/4 threads, so compatibility between blocks/rads/reservoirs isn't something you need to worry about much.
The blocks make no difference but do you want to do hardline tubing or soft tubing?
I just wrote up this flow chart which details the use of fittings in general. Hopefully that sheds some light on your question.
Case Design | CAD | Custom Watercooling Parts | Loop Design | Cable Sleeving and Management
Fittings Guide  |  Most recent completed build: Glass & Aluminium  |  Current build(s): Project Starscream
soft
5 minutes ago, NovaMan01 said:
soft
For soft tubing I would suggest to use thick walled tubing since it doesn't kink as easily when doing tight radius bends. A commonly used sized the 3/8"ID, 5/8"OD for small diameter and 1/2"ID, 3/4"OD for large diameter. The tubing size is up to you and makes little to no difference in performance other than looks.
an ol-timers trick was to use 7/16" ID x 5/8" OD soft tubing on 1/2" barbs as you don't have to use clamps. tough to get on, but once on, nuttin' but a razor blade can remove it.
