I need to build a lab server on the cheap.  It doesn't need to be powerful, but I do need at least 8 cores and at least 32GB RAM as I will be doing a lot of virtualization with it, and would prefer 48-64 GB if possible.  It won't be turned on except when I need it, so only a single PSU is needed.  I have spare hdd's, so don't need those.  Would also like a system that doesn't sound like a turbine engine when turned on.  I would also prefer a tower system vs a rackmount system, but either would work.
My initial thoughts would be to get an old Xeon system from the Sandy or Ivy bridge generation and get a motherboard that uses registered DDR2/DDR3 RAM as it's cheap.  I would also like to keep the total cost at or under $500 if possible, but could go a little higher if required.
Any suggestion on parts or a used system?
https://linustechtips.com/topic/882068-help-me-build-a-lab-server/
Er, Sandybridge is DDR3, so you'd DDR3 for that. I know there are some cheapish 8 core Sandybridge Xeons available now, have a look on ebay and see if there's any cheapish single socket LGA 2011 server boards.
Yours faithfully
23 hours ago, leadeater said:
LGA2011 would be my recommended generation to aim for now days but might still be slightly expensive, LGA1366 is fine but really aging now.
I agree with them but I want to add something, right now you can find on eBay a lot of Xeon E5 .... v3 ES. They are cheap, yes but they shouldn't be for sale because they are engineering sample and might randomly die. I saw few of them at 100-250$ tho (100$ was 8 core and 250$ was something like 12 core).
Problem with that isn't the CPU cost it's the cost of the rest of the system. You can get complete Dell servers for $200-$350 with ram and dual PSU etc.
Edit:
It's a good option if you're wanting to spend a bit more and get something with lower E5v3 CPUs and replace them, or no CPUs.
It was just an warning for those eBay xeons :) nothing more, nothing less, and yeah it will be better to use a complete server.
Check out my HCI build thread if you want an 'out of the box' (literally) take.
https://linustechtips.com/main/topic/836065-build-hci-developmenttest-stack/?tab=comments#comment-10445652
There are lots of well priced pre-builds out there for next to nothing, but older architecture.  '
Let me know if you end up needing DDR3 ECC memory, I have a good amount if 8GB sticks available.
