Nice big warning on primochills website
WARNING: Use of this product with aluminum components (such as aluminum constructed radiators) is not recommended and will void the fluid warranty.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/880500-ekwb-alu-question/#findComment-10886057
It will completely get wrecked by the aluminium so not. Coolants can be directly poured in, but some like the EK-cryoFuel concentrate requires dilution using distilled water, so depends.
https://linustechtips.com/topic/880500-ekwb-alu-question/#findComment-10886144
