I want to change from my massive 750d to a slightly smaller mastercase h500p, only thing is is that I am wanting to know if it is compatible with the Dark Rock Pro 3 since it comes pretty close to the side panel on my 750d.
Thanks in advance
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/880386-case-cpu-fan-compatibility/
2 hours ago, seon123 said:
I have no idea why you would want the H500P, as it's one of, if not the worst cases of the year.
i like it
CPU: i7 4790k
Case: Dark Base 700
11 hours ago, benji_ said:
i like it
Just be prepared for the many, amny, many sacrifices you'll be making. Misleadingly poor airflow, cheap build quality, very "meh" cable management options, Vertical GPU mounts that kill air cooled cards in terms of heat, etc. This case is NOT recommended in its default configuration by any means
