Problems with EK-ACF fittings
Solved by Enderman,
1 minute ago, DavidMO said:Two allen keys came with my entire order - the one to tighten/loosen the caps for the gpu block, and the one to tighten the screws for installing the gpu and backplate.
The inside of the fittings have notches for you to insert an allen key, you can use that to take them apart too.
All you need to do is grip the outer piece with your hand and use the key to turn the inner piece.
Featured Topics
kodokuj ·
Posted in Graphics Cards1 -
.HEXY ·
5
Dedayog ·
Posted in CPUs, Motherboards, and Memory4 -
4
5
mbecker ·
Posted in Peripherals2 -
Prajnaanicca ·
Posted in CPUs, Motherboards, and Memory6 -
7
3
