Would a mic be slower through a USB hub?
By
silasjdemone
in Audio
in Audio
Solved by Tabs,
No, and if the mic is the only thing connected to the hub you won't even have any reduced bandwidth. Just be sure to get a powered hub, otherwise you might as well just get a USB extension cable. USB itself has a maximum transmit distance of 5 meters without a repeater (or powered hub).
Featured Topics
Shadow1789 ·
2
1
JewPacaBraZ ·
Posted in Troubleshooting1 -
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows3 -
7
Faiyaz111 ·
Posted in Graphics Cards0 -
BigChungus1009 ·
Posted in Troubleshooting7 -
Scorpiopt ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
