2 minutes ago, TinyBolts said:
I overclocked my r5 1600 to 3.85ghz on 1.3v and now on cpu-z it says 3 cores and 6 threads instead of 6 cores 12 threads. Help please!
PS: I used ryzen master utility
did you disable any cores? what does it show in task manager?
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10861626
Just now, TinyBolts said:
The task manager says the same
does removing the overclock fix it?
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10861644
Yep stay away from software overclocking especially with Ryzen it just seems to wonky
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10861677
thats the most funky thing i've seen in a long time, losing 2 cores on oc wtf
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10861703
*3 cores
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10861717
Also, im on the bios rn and do u know what DID and FISD means?
idk, but i dont think they are important for cpu overclocking
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10861744
3 hours ago, TinyBolts said:
Yeah they are idk whitch one to change
What’s your motherboard? I was just able to change the core multiplier directly on my Asus Prime B350 Plus.
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
https://linustechtips.com/topic/877749-ryzen-5-1600-problem/#findComment-10862477
