So basically my pc was working fine untill I noticed that even though it was noticing all 16gb of ram I was only able to use 8gb. So I thought id resit the ram first to see if there was an issue. I took them all out and put them back in and now my pc is stuck in a reboot loop and is displaying error codes relating to memory. I have cleared cmos and have tested all sticks and all slots. I find it so strange as the pc was ok before that (other than the not reading all the memory) any ideas on things I can try?
System is
Ryzen 1700
Asus rog strix 1070
Asrock taichi x370
Ballistix lt 16gb 2400
Corsair rm750x
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/
The Taichi is one of the better boards out there for X370. Is the memory kit you are using on the QVL list? Seems like its more the memory thats at fault over the Motherboard.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/#findComment-10861103
To be honest I'm not 100% sure it is on the list but I find it strange it was working fine before? Would you suggest trying one that is 100% on the list and trying to get my money back for the others?
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/#findComment-10861130
System is
Ryzen 1700
Asus rog strix 1070
Asrock taichi x370
Corsair rm750x
Did you try booting with one stick only? With Ryzen, I would definitely make sure the ram is on the QVL.  The memory controller can be quite picky and your ram may not be 100% compatible.
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/#findComment-10861328
I did, yeah. Ok thanks. Reckon bad RAM compat could cause other issues? As I've been having some buzzing noose issues when gpu is under heavy load but ive swapped everything other than the ram and cpu like 3+ times and its still there and it isnt a fan etc.
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/#findComment-10861874
ryzen is very picky about ram still, and since taichi's probably the best board, and the system was working before, return the ram if u can, try to get something b-die or if you don't wanna look that up, get some gskill ram, higher speed the better, ddr3000+ preferred.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/#findComment-10861928
Agreed.  Make sure you aim for Samsung B-die.  I had some G.Skill Flare X ram that worked perfectly at 3200MHz 14-14-14-34 whereas Corsair Vengeance LPX would not boot at 3200MHz.
https://linustechtips.com/topic/877683-asrock-mobo-wont-post/#findComment-10863044
