What is v9 ??
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/87668-v9-virus-help/#findComment-1188553
OMG Conduit........That is shitty! I had a bad experience with it!
https://linustechtips.com/topic/87668-v9-virus-help/#findComment-1188567
did
dident work :/
It could still not be on your PC, the browser extensions and homepage redirects could still be there. Try re-installing your browser. If that still doesn't work, try scanning using HitManPro in safe mode. (spam F8 on boot)
https://linustechtips.com/topic/87668-v9-virus-help/#findComment-1188598
check your hosts file C:\Windows\System32\Drivers\etc\hosts for redirects and remove them :), then check if your browser has any unwanted addons
------------------------------------------------------I HAZ SHINY----------------------------------------------------------
https://linustechtips.com/topic/87668-v9-virus-help/#findComment-1188600
Here is the best way to clean away infections; All can just be downloaded and ran from Windows.
1) AdwCleaner - Run/Scan/Clean. Simple to use. Will reboot system.
2) Run JRT (same site as AdwCleaner if you use Bleepingcomputer.com)
3) Run HitmanPro
4) Finish with ComboFix.
5) Run CCleaner to remove any junk files
Takes about 15 minutes. I recommend to do this every 6 months if you're a safe user.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/87668-v9-virus-help/#findComment-1190273
If you have a system restore point from when it wasn't around, try reverting to that.
No... Infections can get into restore points and cause the same problems again. Just a waste of time imo.
https://linustechtips.com/topic/87668-v9-virus-help/#findComment-1190278
