Hey guys, I need a bit of help with choosing what to put in my new system.
I will be finishing a hardline loop in few days and I am still undecided on what to put inside it as coolant. The build is mostly tempered glass, the tubing are borosilicate glass and the whole build is black/grey/white.
Custom cables are all here with a mix of carbon, platinum grey and white, the fans will be corsair ML 120 Pro's (white). So now it's the time to choose fluid.
I have 3 bottles of VUE (Sterling Silver) but tbh with all the recent news this stuff is a bit of unknown right now and I'm kinda afraid to use it. So it leaves me with the choice of a new coolant that wouldn't clash with the rest of the build.
So far only clear fluid comes to mind, unfortunately, because I don't have any other color accent in my build - but perhaps clear red or clear blue wouldn't look bad? Dunno, what are your thoughts?
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
https://linustechtips.com/topic/876169-help-with-fluid-color/
id run the VUE, just check beforehand if the fluid has settled out. if it has, return it, if it hasent then id run it
Builds:
https://linustechtips.com/topic/876169-help-with-fluid-color/#findComment-10849037
I use grey Vue in 2 systems and its been great for about 3 weeks. No issues with temps or falling out. I've seen some issues with the blue acting a bit weird, Nothing weird from the grey, silver on primochill's discord. I'll post my build below.
https://imgur.com/a/Q7aE8
CPU: Intel Core i7-6850K @ 4.4GHz  | Mobo: Asrock Taichi x99 | Ram:  Corsair - Vengeance LED 32GB (4 x 8GB) DDR4-3000   | SSD: OCZ Agility 4 256GB 2.5" Solid State Drive x 2 | HDD: Western Digital Caviar Black 500GB x 2 | GPU: MSI GTX 1080 ti | Case: Corsair 900D ATX  | PSU: EVGA SuperNOVA 1300 G2  | Sound Card: Schiit  | Cooling: Custom watercooling (All EK blocks)
https://linustechtips.com/topic/876169-help-with-fluid-color/#findComment-10856242
How do you like that case ?
https://linustechtips.com/topic/876169-help-with-fluid-color/#findComment-10856887
I like it, I think Lian Li makes some weird choices. I was able to get it on sale so for $120 it was definitely worth it.
https://linustechtips.com/topic/876169-help-with-fluid-color/#findComment-10863304
Yeah i like some of their stuff,I have been looking at that case in white but the price tag is holding me off for now.
https://linustechtips.com/topic/876169-help-with-fluid-color/#findComment-10863983
