Good Audio Setup?
I was wondering if this would be a good audio setup:
Sennheisers 598s (For some reason they are cheaper than the 558s at Frys so I am getting them)
Zalman Mic 1
Onboard Audio :mellow:
This good? :P
i7 4770k/Asus GTX 1080 TI/Asus RX5500 XT/Corsair Vengeance Pro 16GB/Samsung 840 Pro 256GB/Seagate Barracuda 3TB/AX860i/ASUS Z87 PRO/Fractal Design Define R4/HD 598
https://linustechtips.com/topic/87606-good-audio-setup/
Sure :)
It would be better with a sound card, but that would give you some pretty pretty decent sound ;)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/87606-good-audio-setup/#findComment-1187936
No it wouldn't. A soundcard's high output impedance would make the headphones perform worse than a normal onboard solution.
https://linustechtips.com/topic/87606-good-audio-setup/#findComment-1187945
Oh my mistake :( I thought the headphones had a impedance of 600 since I had meant I had seen that before, but they don´t. Sorry about that.
In that case you are right and a sound card would just ruin the sound :/
Tor
https://linustechtips.com/topic/87606-good-audio-setup/#findComment-1187958
Sound-cards of tunable output impedance, sound-card would be better
X79A GD65 (8D), 3820, 7770, 16GB (1600Mhz cas9), 850watt(ocz zx), storm trooper, h100, xonar xense, sp2500, pc350, asus PA248Q LG 22'' ips, razor black-widow ultimate 2013, 120GB intel 520 series 128GB crucial M4 2*3TB barracuda 2*1TB barracuda 2TB Hitachi
https://linustechtips.com/topic/87606-good-audio-setup/#findComment-1187969
some do have that. I can't remember the name but it was on some headfi youtube video.
the amp had a switch between 1 ohm output or 10 ohm output impedance. iirc
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/87606-good-audio-setup/#findComment-1189248
