Can I connect RGB 120 mm cooler master fan to psu?
By
vatsan
in Power Supplies
in Power Supplies
Solved by SmilesRising,
Just now, vatsan said:Ok my mother board don't have RGB header. If I buy RGB fan and use the RGB fan in normal fan header what colour will I get and will I be able to control it without RGB header ?
if the fan doesnt have a software for it and you dont have a rgb header the fan will most likely do some sort of rainbow loop.
Featured Topics
DreamCat04 ·
Posted in PC Gaming0 -
saltycaramel ·
Posted in Tech News0 -
3
1
VinSen ·
Posted in New Builds and Planning2 -
1
Fahizzle ·
8
