Need Help Finding Motherboard Manual/Documentation.
Go to solution Solved by TrigrH,
It could be this?
I recently bought a new case for my PC but I'm having trouble installing the front panel connections because I can't seem to find any documentation for my motherboard or a manual so that I can know where to connect anything and I'm worried to just connect it to any pin because i don't know if it will cause an damage to my PC or the cases front panel connections.Or if they are color coded and someone can tell me what it means that would be so much appreciated. I have an Acer AG3-605-UR1A.
The Acer AG3-605-UR1A info that you posted is for the computer, not the motherboard.  What we need is the make/model of the motherboard.  That information is usually posted on the motherboard somewhere located near the PCIe slots.
if i were to guess= from the very left bottom
2|4|6|8|10|12|14
1|3|5|7|9  |11|12
1 IS HDD led +
2 is Power LED +
3 is HDD led -
4 is Power LED-
5 reset switch
6 power switch
7 reset switch
8 power switch
9 = reserved
10= the hole
11,12,13,14 idk
let us know it it works
