Hi !
So i wanted to overclock my CPU to 4.4ghz, however when i go into BIOS, it doesn't save the settings. Even loading the optimised settings that Asrock provides, nothing changes. My CPU is stuck at 3.8Ghz , please help.
Also, in my boot priority, only my HDD is visible and SSD isn't.
Specs:
CPU: I5 7600K
MOBO: ASrock fatality z270 gaming k4
https://linustechtips.com/topic/874507-over-clocking-issue/
Make sure turbo boost, c states, speedstep, virtualization technology (unless you use it) are disabled.
Make sure voltage is set to manual mode and at 1.28v.
Make sure all core ratio is set to 44.
Go to the last tab in the bios (advanced mode) and save and exit.
That should increase stability.
https://linustechtips.com/topic/874507-over-clocking-issue/#findComment-10833431
To update bios:
Make sure legacy usb support is enabled.
On a fat32 formatted usb make sure the FILE INSIDE THE ZIP is placed in the root of the USB drive.
http://asrock.pc.cdn.bitgravity.com/BIOS/1151/Z270 Gaming K4(2.10)ROM.zip
Go into the bios and select instant flash, follow the prompts.
https://linustechtips.com/topic/874507-over-clocking-issue/#findComment-10833455
So i extracted files from a ZIP folder that i downloaded from https://www.asrock.com/MB/Intel/Fatal1ty Z270 Gaming K4/index.asp#BIOS , the 2.10 version and formatted it before i actually extracted any files as shown in a video. There is only 1 file though ? is that normal?
https://linustechtips.com/topic/874507-over-clocking-issue/#findComment-10833459
make sure you got the instant flash one, and yes its only a single file in the zip.
https://linustechtips.com/topic/874507-over-clocking-issue/#findComment-10833494
Just now, Woji1 said:
i set every setting as you said i should, i press the exit tab and save and leave. Nothing changes
lmao you are using windows, you need to use CPU-Z, its been working the entire time.
https://linustechtips.com/topic/874507-over-clocking-issue/#findComment-10833521
