Small question for a mining noob.
I just finished my mining rig, but since my parents are also going to be using it, i thought putting a 6450 just to keep the machine running smoothly.
However if i have that card and the 7950, cgminer crashes, obviously when i remove the 6450, cg miner obviously works and mining happily.
Also i want the 6450 to drive the display, to keep the other card running do i need to make the little display dummy adapters?
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/87378-two-graphics-card-on-a-mining-rig/
Add -d 0 to your .Bat to only use the first gpu
Thanks, is there a way to add that without opening the .bat? ( im a noob so yeah sorry )
Ok, are you running cgminer?
yes, mining for the pool : wemineltc, were you can just run a batch file, with all the settings premade
Alright go to the batch file and right click, select edit to open it with notepad.
It will look something like this
cgminer.exe --scrypt -o netcodepool.org:3333 -u AK0490.1 -p x -d 0 --thread-concurrency 8192 --no-submit-stale --intensity 13 --worksize 256 -g 2 --gpu-engine 1046 --gpu-memclock 1500
Just add the  -d 0, if it tries to use only the 6450 change it to -d 1.
You are free, act like it~Warfairy. Moar guns. B) #3Dprinting
Thats the same way i can add custom things to maybe try and optimize it? I wouldnt mind squeezing a few more Kh/s ( though not complaining with 598kh/s on the 7950)
Yes, this is how you optimize it.  Paste your .bat here and I will try to recommend some changes to squeeze out more KH/s.
Edit: Actually at 600Kh/s any improvement are most likely to come from changes in clock speeds, what is the card running at?
Nice, its running now, can i still open the batch file without causing any problems?
Card is running at 1050MHz core and 1400Mhz on memory
You can open it while it's running if that's what you mean.
Try bumping your memory up to 1500 and try the core at 1046 and 1080 and see if you get better results.
Okay thanks again, will post the .bat soon! and will try that too
Okay here it is:
I know if you have my name and passwork you ll mine for me but still lol, and intensity i change after to 19, but i guess i can just change it there for always
You seem to be missing something......
euhm yeah i wrote it but it isnt there, ill write again and put it on this post
PwAjAtF.png?1
Yeah the forum deletes the code, so i put an image of it, if you try and write it, send me a pm or something, i guess that would work
Okay here it is:
You can't post stratum addresses on the forum. Remove the stratum and your post will show up ;) It's annoying as hell, perhaps one day it will get fixed.
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
Ohh okay, well i went the long way around and made a picture lol
PwAjAtF.png?1
Try -I 15 and higher see if it's any better.
There are a lot of other things that you can set manually as well. Here is what I use on my 7950 --thread-concurrency 24768  --intensity 18 --worksize 256  --gpu-engine 1046 --gpu-memclock 1500
Any of these things can just be added to the file with a space between each setting. As you can see in my example this would set the clock speeds for you.
If you are already running at 600KH/s don't expect to much more though, most cards top out at 630-660.
ill try these things out tomorrow! thanks,
With the clock speed changes i get around 630 right now at i=19 ( 1080mhz and 1500mhz )
You should be all set then.
Good luck mining!
Okay so that sort of works i think, the 7950 is mining but the cgminer cmd window is just black, with the little _ flickering, any ideas?
