Hi does the 212 evo cooler fit in h81m-plus?
Solved by paddy-stone,
8 minutes ago, Angel1 said:Hi
So i wanna know if the cpu cooler 212 evo fit in my motherboard
Case / S340
Motherboard / H81m-Plus
It will fit on most motherboards, as long as it says that it fits the SOCKET, so it has the mounting hardware needed. It's the CASE you need to check, to see that it fits with any height restrictions, for example it might say that the 212 cooler is 165mm (this may not be correct it is just an example), so you check your case to see if it mentions cooler height max. Hope that helps.
