Using the baseline of the very gold Asrock X99 OC formula I have been trying to figure out a theme for a complete build for quite some time.  I believe I have found the solution to my problems!  The theme is tentatively named Fading Royalty with colours Gold/purple/black/grey.  The name comes from both the colours and the nature of of the hardware - once this PC would have been the king of gaming and now leaves its crown to its predecessors with dignity.
This thread is my planning/minor update location, I'll be making a proper build log as parts arrive and I start getting things done xD  Looking for leads on relevant cases, having a hard time deciding on one.
Parts
6800k
X99 OC Formula
2*8gb tridentz RGB (it's laughably small on my massive board)
STRIX 980 ti
AX860 with dat custom sleeving (soon to be even more custom)
Watercooling gear!
What I have
Fantastic bitspower 980 ti waterblock
PE360
SE240
10 very battered bitspower 3/8" 5/8"
Laing D5 with 5.25" bayres
EK D5 pumptop
various bits
What I want
D5 tube pump/res? Hopefully heatkiller
12 Primochill Gold rigid fittings
A bunch of VUE in Candy purple
Heatkiller Pro 4 (probably acetal) or EKWB X99 supremacy evo
Maybe a 400mm radiator, if not I may replace the SE with something better
What do you lads and ladies think about these sleeving patter options?"
PCIe 8 + 8 I EPS 8 + 4  I  ATX 24 pin
A gorgeous mobo
Muh GPU
Dat VUE
PC-V32-CP_600x_crop_center.jpg?v=1509987
Gooold fittings
F-RSX12-CGD-12_600x_crop_center.jpg?v=14
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/873440-code-name-project-fading-royalty/
Current parts list
6800k
X99 OC Formula
STRIX 980 ti + BP waterblock
AX 860i with dat custom sleeving
  Hide contents
Dat VUE
  Hide contents
Gooold fittings
  Hide contents
Sounds like a very optimistic (in a good way) approach to a build utilizing components with deplorable color scheme choices from the manufacturer, given the distinct lack of other solid gold colored components. I'd be interested to see your progress.
Also, while you're still using X99, I'd recommend you at least try one of the insane price per core Xeons that exist for 2011-3. They offer very good value for what they are, in fact I think I've already discussed them with you on another occasion.
My main desktop, "Rufus":
PC Specs:
CPU: AMD Ryzen 5 1600
CPU Cooler: Cooler Master MasterLiquid Lite 120
RAM: 2x8gb Corsair Vengence DDR4 Red LED @ 3066mt/s
Motherboard: MSI B350 Gaming Pro Carbon
GPU: XFX RX 580 GTR XXX White
Storage: Mushkin ECO3 256GB SATA3 SSD + Some hitachi thing
PSU: Seasonic Focus Plus Gold 650W
Case: Corsair Crystal 460X
OS: Windows 10 x64 Pro Version 1607
Retro machine:
PC Specs:
CPU: Intel Core 2 Quad Q9550
CPU Cooler: Stock heatsink
RAM: GSkill 4gb DDR2 1066mt/s
Motherboard: Asus P5n-e SLI
GPU: 8800 GTS 640mb, I swap between that and my 8800 GTS 512mb
Storage: Seagate 320gb right from 2006
PSU: Ultra 600W
Case: Deepcool Tesseract SW
OS: Windows XP SP3 32-bit, Linux Mint 18.2 Cinnamon 64-bit, Manjaro Deepin x64 (sorta)
Mac Pro Early 2008: Dual Xeon X5482s w/ 32GB RAM & HD 5770 running macOS High Sierra
More PC's
I'll eventually grab a 1681/1686/1691 v3 if I can, a 10 - 14 core capable of 4.5ghz would be ideal.
For now though I'm bound by monetary restrictions and a 6800k is what I wound up going with
3 minutes ago, Legendarypoet said:
A color scheme worthy of a Titan V. Definitely like the theme.
Thanks, I'm more or less stuck with Primochill fittings (only gold on the market) and have no clue whether or not they are any good :/
Indeed, I would focus on your cosmetic upgrade first as that is the intent of your current project. Watercooling gear, fittings, and custom cables are a steep expense by themselves.
PC Specs:
Retro machine:
PC Specs:
PSU: Ultra 600W
More PC's
Actually, I'm more or less good to go on all of that (once you make your first loop upgrading/changing it gets way cheaper)
For example, I have my radiators, fans, pump, GPU block etc already meaning all I need is coolant and fittings.
Doing the sleeving myself as well
Current parts list
6800k
X99 OC Formula
A gorgeous mobo
  Reveal hidden contents
Muh GPU
Dat VUE
Gooold fittings
looiks a veruy noice
CPU: i7 3820@4.3Ghz GPU: Gtx 1060 RAM: 16gb HyperX Fury CASE: S340 Elite Cpu runs nice and hot ( ͡° ͜ʖ ͡°)
id add more yellow to the wireing, but im kinda biased to the color yellow :P
Builds:
I see.... Bibleman theme...
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
