My 780ti is not working properly, the reason for that is any game that is not demanding it does not use its whole capacity. When I mean it does not use the whole capacity it only uses 5% of it. I only get like 40FPS on everything low on TF2. It is very strange because on high demanding game on BF4 and Assasins creed Black flag on ultra settings maxed out it runs over 60fps. Does anyone know what is going on? If so please answer this question.
My specs: http://gyazo.com/51c14791a0d20a60bd043b009b8f32db
On most games I play it does not use its 100% on GMOD it only uses 17%. What is going on?
Give your meat a good old rub
https://linustechtips.com/topic/87326-780ti-low-gpu-usage/
Gmod is a low GPU eater game, it dont need that much power.
but i dont understand too why it dont give you good fps?
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/87326-780ti-low-gpu-usage/#findComment-1184673
Try turning vsync off if it is not off already
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/87326-780ti-low-gpu-usage/#findComment-1184683
Chances are your playing games that don't use enough of your GPU,
you can't expect a low end game to run 100% on a high end GPU, it
doesn't work like that, alternatively you can enable K-Boost which will
force your card to run at it's boost clock all the time, which will increase
performance, but not make the game use 100% gpu load, in terms of FPS
its tough to say, could be a driver setting such as v-sync being enabled, you
can disable this via the NVidia control panel on the desktop, your game settings
could have v-sync enabled to make sure to disable it in game as well, finally,
limits could be placed in the game itself that's stopping you from achieving your
desired frame rates, which is why I'll get 100+fps on BF4, but no more then 40-60
frames while standing in town in world of warcraft, game optimization is important.
hope this clears up any of your questions!
https://linustechtips.com/topic/87326-780ti-low-gpu-usage/#findComment-1184732
