Hello! So, after watching Jayz2Cents' 2015 overclocking tutorial I have been inspired to suck the sweet, sweet performance out of my GPU that Nvidia has been withholding from me! However, this overclock is multi-purposed - not only would I like this overclock to improve my gaming performance (which, admittedly, is fine but...still want to try to make it fine-er!) but also because I *believe* that this would improve my hash rate when I dip my feet into mining (which is also something I am looking to experiment with, if just for the experience of doing it).
So, what I did was install MSI Afterburner and the Heaven benchmark. However, I am unsure what screen resolution to run this at. I have a 34'' ultrawide monitor (LG -34UM58) with a 2560x1080 screen resolution. However, I see on Jay's tutorial that he is running it for a 1920x1080 monitor. Further confusion, when I set it to 'System' (in the Heaven benchmark) it gives me 1600x900 for testing. Again, since I would like to overclock also to improve mining performance (if that's the right phrase?) which doesn't need to run on an ultrawide monitor, what screen resolution should I be using when bench marking?
As an aside, I have a GTX Titan X (Maxwell) that I got off Facebook Marketplace for $300. I understand that on the list of bang-for-buck GPUs this is not even on the list but...*shrugs* I got it for a good price I think :)
3 minutes ago, Leonard said:
xD
bench at native which is the 2560x1080 at the highest refresh rate.
So, if I could ask a theoretical question then: is there any difference between bench marking at different screen resolutions? Or is the key just that I am consistent with my screen resolutions during testing?
The more variables you create, the harder it becomes to test the gains.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
It really doesn't matter what resolution. As long as it's consistent it's ok.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Okay - a follow-up question: I have a stable (15 min benchmark loop of Heaven) OC before voltage changes at +190MHz on core and +150MHz on memory. So now that I'm including core voltage changes do I just...max it out at +112mV and see what I can move the core clock to? Or does changing the voltage in and of itself need to be incrementally benchmarked?
When OCing, yes there is a difference somewhat, when you OC a GPU at full resolution the OC will be fine/stable for any smaller resolution but if you OC the GPU on a low resolution and then decide to increase the resolution you may very well get issues, which is why it would be best to OC the GPU on the native resolution of the monitor.
A water-cooled mid-tier gaming PC.
