Need a CPU recommendation
Solved by JaegerB,
11 minutes ago, FinalRegiment123 said:Around $300-350
I'll assume USD.
Buying a Ryzen 7 1700 for 300 USD ensures a solid upgrade path and will also save you money on a cooler (since it comes with a really capable one.
For the same price, you could also get an i5 8600k with a couple less cores and would require you to get a decent cooler for it.
In the end it's up to you, but I'd recommend the 1700.
