Stuttering Issue need some help!
Solved by asusfan,
I would say both the Ram and hard drive is causing the problem.
first the memory should be duel channel kit and not a single module.
http://www.msi.com/product/mb/H87-G43-GAMING.html#specification
^^^see specs its duel channel memory^^^
so you need a matched pair (Duel) or a (Quad kit) and check the manufactures manual for recommended kits for that board.
second it would help to have a Sata3 hard drive, less lag. you can now get good SSHD drives now at a good price and storage sizes. look at Seagate they do good hybrid drives in 2.5" or 3.5" sizes.
hope that helps, oh and by the way nice motherboard and CPU
