Weird(?) sound coming from Cooler Master Master Liquid 240
Solved by PineyCreek,
If it's not actually dripping out anywhere, I would wait for CM to respond with their opinion. If you actually had bad air bubbles in your coolant the radiator simply wouldn't work as well (significant heat spikes if really large amount of air, much like a radiator on a mid-engine vehicle), so it's probably not that. Might be the 240 just has a noisier pump.
Featured Topics
bensinspade ·
Posted in Graphics Cards2 -
CloseTheDoor ·
Posted in New Builds and Planning7 -
pchelp ·
Posted in CPUs, Motherboards, and Memory14 -
pontikos ·
Posted in Troubleshooting2 -
9
wolfgangam ·
Posted in Windows3 -
12
