Help me
Go to solution Solved by Tiberiusisgame,
I agree with the call for a 4790k because you have a Z97 board. You can OC it, you'll have 8 threads, it'll keep for a few years before you upgrade your graphics card.
Try and find a used i7 4770K or 4790K
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/872094-help-me/#findComment-10811115
Just now, Lowspecgamer said:
I have a gtx 1050 2gb,8gb ram, and a pentium g3258 @4.2ghz.What cpu,mobo, and tan should I get ? I have a 350 budget my gpu is fine for now unless you think something different tell me?
depending on your current motherboard, perhaps just a new cpu ?
the 4690 (or 4690k if you're into overclocking and have a z97 board) is a really good option for you.
https://linustechtips.com/topic/872094-help-me/#findComment-10811116
I have lga 1150 cpu I want to upgrade to 1151
You don't really have to build a whole new system, just upgrade your CPU.
زندگی از چراغ
https://linustechtips.com/topic/872094-help-me/#findComment-10811134
no I ment motherboard (model number, chipset...)
I don't see any benefits to going to a 1151 cpu. a 4790(i7) or 4690 (i5)
is a MUCH better option for your money than switching platforms.
https://linustechtips.com/topic/872094-help-me/#findComment-10811137
By switching to a 1151 socket and board not only you will have to switch board and cpu but also (yes, there are some ddr3 options, but they are scarce) switch ram for ddr4.
for 350$ it is not even close to being worth it compared to a used 4690(k)-4790(k)
here, look at the price :
https://www.ebay.com/itm/Intel-Core-i7-4790-i7-4790-3-6GHz-LGA1150-SR1QF-8M-Cache-Processor-CPU/182949598346?hash=item2a98a5548a:g:ERUAAOSwbwJaKGQD
also, with the money left, if you don't already have an SSD. well, there's a good upgrade for you too !
https://linustechtips.com/topic/872094-help-me/#findComment-10811146
Well that’s what I want to do so if I do that what cpu should I get that’s lga 1151 because my local microcenter doesn’t carry lga 1150 anymore
https://linustechtips.com/topic/872094-help-me/#findComment-10811148
Your GPU is enough to play 1080p 30+ fps in mid settings.
for $350
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.89 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2666 Memory  ($87.99 @ Amazon)
Total: $347.87
Generated by PCPartPicker 2017-12-11 13:53 EST-0500
Sell your pentium and mobo and add another 8gb and you're golden...
https://linustechtips.com/topic/872094-help-me/#findComment-10811151
There's no point in upgrading to LGA 1151, just find a used i7 4770K or 4790K on Ebay.
زندگی از چراغ
https://linustechtips.com/topic/872094-help-me/#findComment-10811152
buy it used. there's no point in sticking to new stuff here.
you wil get LESS for your money than if you bought a used 4790(k) or 4690(k)
https://linustechtips.com/topic/872094-help-me/#findComment-10811155
Why sell the board? just upgrading the CPU to an i7 4770K or 4790K would make so much more sense in this case.
زندگی از چراغ
https://linustechtips.com/topic/872094-help-me/#findComment-10811158
for $350
  Hide contents
Total: $347.87
he has to sell his current 8gb, its ddr3 not 4
https://linustechtips.com/topic/872094-help-me/#findComment-10811159
Ik but in the future what else will I get if I’m using old stuff
bro, I own a 4790k and I don't expect to have to change it for at least 4-5 years still
by then you'll have much better prices for DDR4 and much better cpu's worth the switch.
https://linustechtips.com/topic/872094-help-me/#findComment-10811166
For $350 i would just buy a Ryzen new system.
$150 made more sense to just upgrade cpu.
https://linustechtips.com/topic/872094-help-me/#findComment-10811167
8gb DDR4 already in the list.
He can add another after selling the 8gb ddr3 alone + bonus from the cpu & mobo.
https://linustechtips.com/topic/872094-help-me/#findComment-10811173
Are you for real? his current board is a Z97 and all it needs is an i7 4770K or 4790K to make it a much better machine.
زندگی از چراغ
https://linustechtips.com/topic/872094-help-me/#findComment-10811175
He can add another after selling the pentium and mobo.
ooh I thought you ment "adding this ddr4 to your current ram"
as if it were optional to buy more ram.
i understand now xD
https://linustechtips.com/topic/872094-help-me/#findComment-10811177
You need to make peace with reality. You have $350. @givingtnt made a great point about the SSD. Get a cheaper one for less than $100 (but avoid those without DRAM, as Linus recently mentioned in an AFAP video) and save the rest for a better upgrade down the road since it seems like you would prefer not to buy used gear.
https://linustechtips.com/topic/872094-help-me/#findComment-10811182
is it ?
he hasn't said yet. we can'T determin what mobo he has based on his cpu.
@Lowspecgamer can you please give us your motherboard number ??
https://linustechtips.com/topic/872094-help-me/#findComment-10811187
