Find your front panel headers (look in the manual if you can't spot them)
then, plug the cables into the correct pins. the layout is indicated by writing on the board itself, and in the instruction booklet.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
8 minutes ago, mike123159 said:
So I have the s340 elite and I'm trying to find how to plug the hdd led, p led +, p led -, and the power sw. Motherboard is asrock killer sli/ac z270
Usually the headers are located on the bottom right side of the motherboard.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
3 minutes ago, Froody129 said:
All the headers will be on the bottom of the motherboard. Check your manual if it isn't clear which pins go where on the board. Make sure not to mix up your positive and negative is there a difference between ground and negative pins??????
2 minutes ago, mike123159 said:
Yes, some of the connectors will have a positive and negative pin. This is very clearly labelled on the plug itself and the motherboard manual will show you exactly where each one needs to go. Feel free to ask for help if you need
That's an F in the profile pic
7 hours ago, Bcat00 said:
Really now, why isn't he referring to his instruction paper that came with his board?
This is one of the few instances where i would trust a outdated piece of paper vs advice from the forum.
I said im new to building a pc, so it isn't very clear for me xD
8 hours ago, wONKEyeYEs said:
Here is the front io header on your board.
The power and reset don't matter which way they're plugged in.
The HDD LED and power LED matter, but nothing bad happens if
you plug them in reversed it just won.t light up.
so my problem is the hdd led, the bottom left is positive, then the one next to it is negative, then ground. how do I put it in positve and ground if the hdd led is 1 cable?
