Car Subwoofer
30op
Heya,
I'm looking at putting a sub into my car, I already have a head unit so don't need any adaptors.
I'd like to know a bit about RMS and what amps should match with the best subs. I'd like to spend as little as possible.
These are the combo I've been looking at would they work? and what does it mean by 2x75w (this is the amp) does that mean I cant connect a single 150w sub.
http://www.halfords.com/technology/car-audio/car-amps-subs/edge-ed7300-2-channel-stereo-amplifier
https://www.amazon.co.uk/gp/product/B00T82PDGM/ref=ox_sc_act_title_1?smid=A3P5ROKL5A1OLE&psc=1
If not can someone post a good combo. The most i'm willing to spend is £250, I will go over a bit if its worth it!!
##### 69th Post #####
10 minutes ago, ImHyperstyle said:
One thing I do know is the sub won't do 1300W RMS
The sub ain't 1300w RMS, that is peak, RMS is probably half the peak or less
CPU: Intel Core I7 7700K & Corsair H100i v2
Mobo: Asus Maximus IX Hero
RAM: 32 Gigs @ 3000Mhz, Corsair Dominator Platinum
GPU: Asus Strix 1080 A8G
Storage: Samsung 840 EVO 500gb
PSU: Corsair HX750i
Case: Fractal Design Define S
RMS is ~70.7% of peak. So 920w about.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
Alright, all car stereo speakers that I've looked at was specified with half the RMS as half the peak , that's what I was basing my comment on.
PSU: Corsair HX750i
Ya know, I might have actually been wrong when I corrected you. RMS for voltage is 70.7% the peak voltage, just realized it might not be the same for wattage. I apologize for correcting you.
First time I have actually seen a discussion ending with agreeing to each other on the interwebs
PSU: Corsair HX750i
Haha, people are generally more civil around here than other forums.
