I've looked and looked and still can't find any 92mm cpu fans that fave any good reviews, what are some good 92mm fans that cost less than $15?
Also, can case fans be used for a cpu fan?
CPU: AMD FX 8320e | Mobo: Gigabyte GA‑78LMT‑USB3 | Cooler: Cooler Master Hyper n520 | RAM: 8Gb @ 1333MHz
GPU: Gigabyte GTX 1060 mITX | PSU: Antec HCG 520w | Storage: Sandisk 120GB - WD Red 1TB | Case: Modded IBM A50 sleeper
All displayed on an AOC I2421VWH
https://linustechtips.com/topic/87005-92mm-cpu-fans/
you can use case fans, as long as they are the correct size and have enough static pressure
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1180553
not sure how to find it's static pressure. I'm terrible with fans.
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1180567
Go grab the Noctua 92mm fans or Gelid Wing.
....good 92mm fans that cost less than $15?
I need to get 2 and can't go over $30
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1180581
If you need PWM, go for the first link...if other check out link 2....while you are on the site, check out more options...good luck.
http://www.frozencpu.com/products/11777/fan-774/Akasa_92mm_x_25mm_Smart_and_Cool_PWM_Fan_AK-FN052.html?tl=g36c365s940
http://www.frozencpu.com/products/13290/fan-873/Gelid_Solutions_Silent_9_92mm_x_25mm_Silent_Case_Fan_-_1500_RPM_FN-SX09-15.html?tl=g36c15s59
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1186320
What kind of dollars are you using?
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1188879
USD$
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1195951
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1196312
I guess the Noctuas might be out of your range, but I have to ask:
What kinda CPU cooler takes two 92mm fans?
That sexy Coolermaster Hyper N520 :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103057&Tpk=cooler%20master%20hyper%20n520
It works really well, the fans are just too loud.
https://linustechtips.com/topic/87005-92mm-cpu-fans/#findComment-1196964
