Hey, I am looking to upgrade my PC at the end of the year, I already have 3200mhz cl14 DDR4 RAM, but I really don't know what CPU to get. I am thinking the i5-8600k as I am mainly going to be gaming and it sounds like it beats most of ryzen for gaming, but if I do plan to do a very light amount of streaming would ryzen be worth it? I'd prefer intel but im not sure
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/869854-cpu-choice-help/
8600k ($299) won only by 5% margin, so i say ryzen 1600x ($230).
Ryzen 1600 also a good choice at $190.
Motherboard for ryzen is cheaper than intel 300 series board which sells for $110 the cheapest.
You could get a decent b350 mobo for $70.
You'll save $100 in total.
https://linustechtips.com/topic/869854-cpu-choice-help/#findComment-10795030
I am not an AMD user, but are there any caveats related to the ryzen?
This is entirely not related to the OP or Supa response, but I am curious if more cores/threads do not always mean better performance...Check this video editing comparison -Not Streaming Related Video-
Desktop Specs
Desktop:
CPU Intel i9-7900x - Motherboard Gigabyte X299 Aorus Gaming 9 - GPU ZOTAC GeForce GTX 1080 Ti AMP Extreme Core Edition - Boot Disk Samsung 960 PRO 512 GB NVMe M.2 PCIe SSD - 2nd Disk Samsung 850 Evo 2 TB SATA SSD - Ram 32 GB (4x8) Corsair Vengeance LED DDR4 C16 - Case NZXT H440 White/Black - PSU NZXT HALE82 V2 700W - CPU Cooler NZXT Kraken AIO X62 280mm - Fans 3 x NZXT AER RGB 140 mm - RGB Controller NZXT HUE+ - Internal USB Hub NZXT - Monitor Samsung U28E850R LED 4K Monitor 60 Hz @ 1440p - Audio Creative Sound Blaster X7 DAC/AMP - Headphones Sennheiser HD650, Bose QuietControl 30, and Bose QuietComfort 35 - Optical Drives Pioneer BD-RW BDR-UD03 (USB 3) and Hitachi-LG BD-RE BU40N (USB 3) - Keyboard EMISH K8 104 Keys Mechanical Gaming Keyboard LED Backlit - Mouse EMISH Gaming Mouse LED Backlit - Chair AkRacing Gaming Chair Deluxe Full Leather Onyx Black - OS MS Windows 10 X64 Pro
File Storage:
OS LT unRaid 6.3.5 Pro  - CPU Intel Xeon 1230 V5 - Motherboard Supermicro X11SAT-F-O - Ram Samsung 16 GB (2x8) DDR4-2133 ECC Un-Buffer - Case NORCO 4U Rack Mount 24 x Hot-Swappable RPC-4224 - Controller LSI 3 x 9211-8i  - PSU Seasonic 1000 W Prime (80 + Platinum) - Fans Noctua 3 x 120 mm & 2 x 80 mm - HDDs WD Red 5 x 10 TB & 8 x 8 TB (Dual Parity)
https://linustechtips.com/topic/869854-cpu-choice-help/#findComment-10795132
There are caveats from ryzen as it still relatively lower clock speed compared to intel means lower Instructions Per Clock (IPC).
And as you can see in the video, tasks that are optimized for more threads seems to favor ryzen.
Right now intel is the IPC king no doubt. But comes in higher price too. You pay 50% more for the same class.
Choose Ryzen if you valued price to performance ratio.
But anyway if you have high end GPU those task will perform way faster if you use the mercury engine as oppose to cpu.
https://linustechtips.com/topic/869854-cpu-choice-help/#findComment-10795178
I don't own AMD CPU, but the fact that they offer good CPUs @ reasonable prices is really great for many people which is a big plus for all of us...
Desktop Specs
Desktop:
File Storage:
https://linustechtips.com/topic/869854-cpu-choice-help/#findComment-10795299
Yes, im sure if theres no ryzen there won't be intel i9 too xD.
Competitions creates innovations.
https://linustechtips.com/topic/869854-cpu-choice-help/#findComment-10795518
you could go with the r5 1600  and use the stock cooler to save money, or get the cheapest z370 motherboard and go with the i7 8700 (330usd, almost the same as the 8600k in games, but smokes it with the extra threads, i.e. streaming, kills the ryzens too) , don't go with the 8600k for the same price. You need a good cooler to oc the 8600k, but you have a free stock cooler for the 1600, 1700, and can use a cheap mobo and cooler for the 8700.
Ryzen depends on the exact ram that you got. I give intel the edge on this one.
If the ram you got happens to be flare x cl14, then ryzen isnt a bad choice.
So if you are really tight on budget, go with the r5 1600, if not i7 8700/8700k depending on ur budget.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/869854-cpu-choice-help/#findComment-10796092
