Hey guys.
I am sure, that I might asked in the past, but can't find the topic any way.
So I will ask again.
I bought the HyperX Beast 1600mhz 16GB, which said that can be overclocked to 2400 .
I did changed in bios the settings, to allow it to be overclocked, as well set it to 1866 .
It didn't give me any issues.
But latter when I tried to hit over 2000, for some reason , the PC just wouldn't start .
It would keep switch on and off.
Can any one please explain why ?
As well, is it possible that my mother board is not compatible , and this is the reason. But also, if it is not, how did it managed to do it before?
The reason I want it to be overclocked, is cause i bought it for this purpose.
(Though , at first i was sure, that it main speed it self is 2400 )
Any thoughts on this please?
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
https://linustechtips.com/topic/868468-overclocking-ram-issues-please-advice/
You can't just set the frequency, you have to enable XMP, or set the memory timings manually in addition to the frequency.
@MageTank knows lots about RAM overclocking. his guide is in my sig, and you can also ask him directly if his guide doesn't help you.
the PC's not booting because the OC isn't stable. add more voltage, loosen timings, or just lower clockspeed. (in many cases, timings are as important or more important than clockspeed)
keep in mind that overclocking is never guaranteed.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Thx. I will try so.
