I feel like "14 fan" and "mobile" don't go together. Unless they're sub-80mm fans...
https://linustechtips.com/topic/867917-14-fan-mobile-pc-case/#findComment-10772827
Its mobile and high end that dont go together. The case isnt for everyone, just like anyother case. However if you want to have a power house and want to be able to take it places, my case works well. You want to take it to the office everyday go get something else, clearly I was not going for a small light case. Price is not to bad with finding a pelican for 85 locally. I had a custom bracket made for more strength to the rad. Otherwise the high costs are in the fans and 1080 radiator which would be the same in a traditional case mount. The expensive part is having that feature to begin with. You guys sound more like facebook, i was looking for geeks wanting powerfull computers.
https://linustechtips.com/topic/867917-14-fan-mobile-pc-case/#findComment-10772983
