http://www.bestbuy.com/site/cooling-fan-heatsink/1305218862.p?id=mp1305218862&skuId=1305218862&st=noctua&cp=2&lp=1 - will this fit with my vengeance ram? Check signature for full specs :D
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/86730-noctua-fan/
you should check the noctua website, go find the product and click compatibility. Their website is fantastic for information like this however if i remember correctly d14's only fit low profile vengeance ram and vengeance pro not the original vengeance. Just double check though
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
https://linustechtips.com/topic/86730-noctua-fan/#findComment-1177558
It doesnt fit, I checked. So what would be another good cooling solution from noctua that would fit?
https://linustechtips.com/topic/86730-noctua-fan/#findComment-1177580
maybe the u12s or the 140mm version
https://linustechtips.com/topic/86730-noctua-fan/#findComment-1177585
Are you stuck on Noctua? You could look at Phanteks coolers - arguably almost as good...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/86730-noctua-fan/#findComment-1177675
I believe that Vengeance Pro is bit higher than original and so D14 wouldn't fit with those either. With NH-U14S (or U12S) there's no clearence issues. Or shouldn't be but Noctuas site is down and I can't check it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/86730-noctua-fan/#findComment-1177932
